I am using the Roland DJ 808 with VDJ 2018 4504 build I would like to use the TR-S to work the scratch DNA. I would like to be able to use the buttons to trigger each sound and sync like if i was using the pads. I would also like to use a bank to trigger saved samples i have read the manual but can not figure it out.
geposted Tue 31 Jul 18 @ 5:16 pm
