Topic: scratch DNA and Sampler
is threr a way to add the scratch DNA to the sampler list so it can be pulled up on the pads without going to the drop down list
geposted Sat 04 Aug 18 @ 2:41 am
geposted Sat 04 Aug 18 @ 2:42 am
Not sure I follow you. Scratch DNA is an audio effect, not some samples, so can't be added in the Sampler as a Sampler Bank. What you can do though is to apply a Sound a Effect to the playing samples. Check the Sampler FX pads page from the Addons.
So what kind of automation are you looking for ?
geposted Sat 04 Aug 18 @ 6:58 am
How do i upgrade dna scratch pads
geposted Mon 29 Apr 19 @ 7:13 pm
