What do you folks see as the easiest way to get to entire music library across a couple of devices? Thanks for your input :)
geposted Sun 05 Aug 18 @ 1:58 am
Put your entire library on both machines.
Some may suggest using an external drive, but what if something happens to it? You need two, right? A 'live' one and a backup. Putting your library directly on the two machines gives you that, with no external drive involved.
geposted Sun 05 Aug 18 @ 7:06 am
Ok, that's what I'm wondering about...what's the easiest way to put it on both machines, and keep both libraries updated?
Thank you for your reply :)
geposted Wed 08 Aug 18 @ 12:56 am
I use FreeFileSync to synchronize computers and for some backups. I have one computer as the master and do all of my database manipulation on that one then sync to the other using the mirror option.
It works for me - it’s pretty easy to use.
geposted Wed 08 Aug 18 @ 2:06 am
What about using a USB flash drive (or a faster one: M2 SSD in external case) and backup the device from time to time (maybe after finishing prep for the gig and before starting to DJ)? In case you are are on Windows you can use robocopy to only backup the diff (files that changed).
geposted Thu 09 Aug 18 @ 3:54 pm
Fastest, i think would be networked connection, My last machine update I "made" a cross over patch lead (extrortioate to buy, but about e10 to buy a regular rj45 patch, punch down tool & modual)
and it transfered at near full 100MB (or maybe Mb)
I honestly don't know the limit of usb3 but since I'm installing cat7 in offices, I'll hazard a guess networked is fasterist.
geposted Thu 09 Aug 18 @ 6:17 pm
WiFi 802.11g - 54Mbps
Regular network - 100Mbps
USB2 - 480Mbps
Fast network - 1Gbps (still not available on every router)
Wifi 802.11ac (max achievable, typical is a bit lower) - 1.3Gbps
USB3 - 5Gbps (some ports up to 10Gbps, and I believe 20Gbps is planned)
Pro network - 10Gbps (I don't think I've seen any consumer routers that support this)
Note that regular single hard drives will be able to read/write at about 100MB/sec or 800Mbps
USB2 - 480Mbps
geposted Thu 09 Aug 18 @ 6:33 pm
Thanks for that info, I guessed that the i/o hard limit would be HD access times .
Explains why fibre to the desktop ain't a thing yet.
(Seriously considering fibre to my house, then become a isp to my neighbours)
geposted Thu 09 Aug 18 @ 6:49 pm
Another plug for FreeFileSync - it does everything Robocopy does (at least everything I ever used Robocopy for) but is graphical and highly configurable. And you can save profiles for different uses.
BTW I last copied my media library (a few hundred gigabytes) over network (wired) in about two hours.
External USB SSD will also be fast.
geposted Thu 09 Aug 18 @ 10:52 pm
Excellent, thanks peeps!
geposted Sat 11 Aug 18 @ 4:16 pm
This is my current process for keeping my libraries on my primary and secondary in sync and the library backed up.
Any and all new music is loaded on the primary. A minimum of once a week I use AllWay Sync (purchased this over 10 years.. lifetime upgrades) to sync up to my home server (this serves as my primary backup). It is based on LimeTech's Unraid technology so it has built in redundancy. Second I sync the music on the secondary laptop to the library on the home server. Then about once a month I sync the library on the primary laptop to SSD external and keep it somewhere off-site.
Should something catastrophic happen to my house the off-site backup is still safe. You can usually buy new equipment fairly quickly; but acquiring and rebuilding a large music library does not happen in a few days.
geposted Sat 11 Aug 18 @ 5:24 pm
