Increase tone information font size? It is too small! thanks
geposted Thu 09 Aug 18 @ 8:39 pm
On what skin?
geposted Fri 10 Aug 18 @ 4:45 pm
classic skin
geposted Fri 10 Aug 18 @ 9:36 pm
OK well this should be in the skin forum, but...
It looks me to as if the EQ font size is under define class "knobk". In the <button> section of that class you'll see text and textselected are both size="13". That seems to be the adjustment you require.
I used the 2 deck skin to find this. It may be different in the others.
geposted Sat 11 Aug 18 @ 6:55 am
Thanks fot the answer, but I don´t understand how to do it,
Could you please explain it to me with a step by step?
Many thanks in advance
geposted Sun 19 Aug 18 @ 6:06 pm
