I am trying to get the 4 decks to all be sync'd when moving the pitch slider to change the tempo.
I am using the std VDJ8 skin with a reloop touch.
I have tried switching on the "beatlocks", visible when on the scratch mode of the skin.
I can't see that this does anything?
I have also tried switching on "pitchlock" in the audio menu under options.
This did sort of work, but is no longer working at all.
The way I was testing this was to load the main song in deck 1 with the pitch slider centred and deck set to master, then loading 3 other songs in decks 2 to 4, sync'd to deck 1. Then with out playing any songs, I would adjust the deck 1 pitch slider to see if all the decks would change tempo in sync.
Could someone please explain in more detail than the manual what both of these controls do?
Because from the manual, my understanding is that they both are supposed to do the exact same thing, but have different names. I'm sure I am misunderstanding something and just need a better explanation.
Is there a problem with this function being used on the reloop touch? Can someone please test?
EDIT: I have found that after selecting yes in the options menu for pitchlock, when I look again in the options menu it has deselected itself.
geposted Mon 13 Aug 18 @ 2:00 am
Here is a bit more info. It's the last 2:
geposted Mon 13 Aug 18 @ 4:31 am
