About VirtualDJ and DJing in general
If you need extended support, contact our Support Team.
Forum Guidelines  (*) The moderators hold the rights to move or modify posts in order to keep the discussions clear or to facilitate the search.
Topic: USB 3.0 Issue - VDJ & NS6
Hello - Just setup my new Lenovo Yoga 730-15 out of the box. Installed latest NS6 driver and running VDJ 7.4.7 as I haven't gotten the time to learn 8 yet. When I load up a song and play, it stars crackling and the song wont play, just crawls very slowly and it's very frustrating. The laptop only has two USB 3.0 ports and from Numarks forums, it states the NS6 IS compatible with 3.0, it just performs at 2.0 speeds. Thoughts?
geposted Wed 15 Aug 18 @ 12:21 am
Intenta cambiar el cable USB, si no te da te recomiendo pasarte a la versión 8 ya que la 7 no tiene soporte, además ya son 4 años que tiene la versión 8, si manejas muy bien la 7 no tendrás problema con la 8
Aquí te dejo unos videos que te ayudarán a familiarizarse con virtual dj 8 es muy fácil y son vídeos cortos les puedes dedicar una tarde o poco a poco y en menos de una semana estarás ducho
https://youtu.be/KTQsXvTq40s
Quedó pendiente
geposted Wed 15 Aug 18 @ 4:21 am
Thank you, but upgrading to Virtual DJ 8 does not resolve my issue. Anyone else have any suggestions?
geposted Wed 15 Aug 18 @ 11:58 pm
This is not an Issue from Virtual DJ Program.
This an Issue by the USB3.
I use also the NS6 from Numark.
I bought it 5 Years ago , and I had also this Problem ..
The Sound Stutter and Krack...
I contact the Numark Support and they explained Me this Problem.
It is due to the USB3 controller chips.
Most sound cards and audio interfaces do not work with USB3.
Numark said it is because the USB2 continuously sends data as is the case with sound cards and USB3 does not.
So in the way I remember Numark told me that via email.
It's probably a problem with Intel chips.
Best Numark cover letter, they'll explain the problem to you better.
Greatings Dani
geposted Thu 16 Aug 18 @ 4:09 pm
Greatings Dani
Thanks. I believe I have resolved the issue on my new laptop. I am gigging tomorrow so we'll see how it goes!
geposted Sat 18 Aug 18 @ 6:29 am
Ok . Thats fine.
What have You done to resolve the issue?
Greatings Dani
geposted Sat 18 Aug 18 @ 12:24 pm
