I updated my VDJ8 to the current 8.3b4514.
Even if I diable the Skin3FxLayout by clicking on the effect GUI or in the VDJ setting section, after a new start of VDJ, the Skin3FxLayout is enabled again. I can confirm, that the setting is saved correct in the setting.xml <skin3FxLayout>no</skin3FxLayout>. But after a VDJ start, It will be changed in the GUI immediate back to <skin3FxLayout>yes,yes</skin3FxLayout>
- I do not use a 3rd party Skin
- This behaviour is only on one PC
- I exchange the setting.xml completly from a setup where this behaviour do not occur, but no success
- I disconnect the Midi controller as well, but same behaviour
Any idea, why the skin3FxLayout will always be enabled again?
Thank you
Thank you
geposted Fri 17 Aug 18 @ 4:25 pm
