Topic: ISSUES WITH CDJ 2000NSX2 JOG WHEELS
ark17PRO SubscriberMember since 2010
Hello,
I use VDJ with the CDJ 2000NXS2s in HID mode. Everything works well except for the jogwheel in vinyl mode. When i touch the jogwheel to stop or cue up a track, it skips and the track stops as well. I'm then unable to to spin the jog to find a point. Instead, it jumps all over the track so essentially I can't use the jogwheels during my sets. Any ideas on how to rectify this?
I'm using VDJ 8.2 with updated CDJs.
Cheers
geposted Sun 19 Aug 18 @ 2:27 pm
Working fine here.
Make sure in Config->Controllers the 'factory default' mapping is selected for the CDJ2000NXS2.
Also try to use the Vinyl button to toggle vinyl mode on/off on the cdj to see if that makes a difference.
geposted Sun 19 Aug 18 @ 5:42 pm
Yes. Did all of that. No idea why there's an issue still.
geposted Tue 21 Aug 18 @ 6:41 am
It's the same when you touch the jog wheel while the track is playing, or when it's stopped?
geposted Tue 21 Aug 18 @ 7:22 am
