Topic: toshiba satellite p200 144 odd problem
speng1PRO InfinityMember since 2010
I have the above with a Intel Core T7200 @ 2.0 GHZ.
The problem is virtual dj 8 will open and just crashes. The song will load on the deck but the deck wont spin although I can hear the song and then it will freeze and the only way to end it is by using windows task manager.
64 bit os.fresh install. Im baffled ?
Nvidia Go G force 7600.
4gb ram installed although 3gb usable that's another issue. updated the bios. Any help on this please
geposted Mon 20 Aug 18 @ 9:20 pm
Update. Virtual DJ 7 works fine but not 8 ?
geposted Mon 20 Aug 18 @ 9:25 pm
