Good afternoon, My Virtual dj was working fine, but suddenly the screen started to flicker with no reason, I did everything, but when I clicked on the FX bottom or settings one, the display was flickering and there weren't any solution at all, this is what I did:
*Unistall virtual dj re install it, didn't work
*update all the drivers, didnt' work
*deleted all settings I had, didn't work
*Came to my mind to reinstall windows cuz I though was the system, too crazy because the problem was only with virtual dj.
* I tried everything that was on the forum, not solution at all
* Did the fullscreen video to put 1, nothing
This was the solution, I went to validate if the video driver was completly updated, I have AMD Radeon R5 M230, and this one Intel(R) HD Graphics Family, I made to update both and was a message that'd say: Both video drivers are completly updated, so I discarded that option, but that made think the issue was even more weird, so I decided to disable the AMD and boala the problem was solved, I think that was something with the update, so I will have to wait to next one. Alright guys that was it for now.
geposted Wed 22 Aug 18 @ 10:06 pm
Jake Dustino wrote :
boala
Eh? Is that any relation to the koala?
geposted Thu 23 Aug 18 @ 5:06 pm
