Topic: VDJ 8 2018 NOT searching by KEY
Hey,
I've just got the 2018 latest VDJ!!! And compared to VDJ 7 it's not 1) letting me search by by KEY in the browser even though it's selected as a field.
2) The KEY detection in VDJ 8 is totally off from VDJ 7 - VDJ 7 was way more accurate then VDJ8!!! Is this a bug??? Can anyone help????
***Ps I have set KEY DETECTION to ELECTRONIC as that's what i use****
geposted Fri 24 Aug 18 @ 1:16 pm
1. I can search by key in 8, and just tested, even though I don't use that field.
2. The detection key is more accurate in 8. Yes, it will change the 7 key results, to be more accurate. It will be best to take a few folders at a time to reanalyze, or do it overnight.
3. Open options, and type "key". Make sure all options match your choices.
