Hello Virtual Dj,
I'm not sure if we already have this features,
How do you put the Virtual Folder 3 under Virtual Folder 2, i just find it hard to move around the Virtual Folder and sub folder when dragging it using mouse.
I wish there is an arrow key to use to move around selected Virtual Folder, we can add this on the left side space where the GO TO Last Folder is located.
I attached a sample screenshot.
Thank you.
Thank you.
geposted Fri 24 Aug 18 @ 2:41 pm
Drag and drop over virtual folder should put it inside there
geposted Fri 24 Aug 18 @ 3:07 pm
Hello, i tried doing the following, the virtual folder 3 ended up as a subfolder of virtual folder 2 (scenario1) and also tried different way (scenario2):
scenario1
Virtual Folder (Main)
|— VF1
|— VF2
|——| VF3
scenario2
Virtual Folder (main)
|— VF3
|— VF1
|— VF2
in SDJ i can drag and drop the folder easy.
scenario1
|— VF1
|— VF2
|——| VF3
scenario2
|— VF3
|— VF1
|— VF2
geposted Fri 24 Aug 18 @ 5:11 pm
