Hi,
I'm having an issue where the Cue buttons on the right deck (after several hours 3+hours into a gig) will stop functioning, and also stop functioning in Virtual DJ. The only way to fix it, is to unplug the USB cable and reconnect it.
I've updated the drivers/firmware and Virtual DJ. Also replaced my laptop.
Has anyone else seen this issue or know how to fix it?
Thanks,
Jamie
Thanks,
Jamie
geposted Mon 27 Aug 18 @ 6:02 am
Maybe the buttons have started wearing out ?
It's common that when buttons start tearing out the symptoms appear after some hours of usage and go away temporarily after some hours of inactivity.
geposted Mon 27 Aug 18 @ 8:05 am
That's puzzling. I would think once buttons are bad they don't get any better on their own. I am thinking the likes of computer keyboard keys. I could be wrong.
geposted Mon 27 Aug 18 @ 2:45 pm
It doesn't appear to be related to Physical buttons on the controller, as the Virtual DJ software buttons also do not work.
The play button works, just not the right deck cueing.
geposted Wed 29 Aug 18 @ 8:27 am
Any chance the right deck "SHIFT" button stucks ?
geposted Wed 29 Aug 18 @ 8:46 am
