Topic: Autostart Recording bug
This bug is in 32bit and 64bit build 4514
Playing a sample does not start recording with the following settings enabled.
geposted Mon 27 Aug 18 @ 8:05 pm
From Sampler Options (dot button in Sampler Sideview)-->Audio Output is set to Master ?
If so, perhaps the Sampler Volume is down and probably you dont get any VU Master activity either.
geposted Mon 27 Aug 18 @ 8:18 pm
sampler is set to master and sampler volume is @ 100% ... i can hear the sample play and the VU meter moves.
also samples do record once recording has started. they will just not start the recording process.
i was under the impression wait for sound meant any sound including samples.
geposted Tue 28 Aug 18 @ 12:27 am
has anyone had a chance to test this ... if I am the only one I will try deleting settings.xml
geposted Wed 29 Aug 18 @ 10:08 am
Works fine here
-Click start record
-Waiting for sound... appears
-Start a sample
-Recording starts
Do you also see the VU meter on the record page moving when you start the sample?
geposted Wed 29 Aug 18 @ 10:18 am
i am not clicking record ... I have Auto Start Recording enabled
if it's not intended to work that way ...
geposted Wed 29 Aug 18 @ 10:19 am
recordAutoStart indeed only works by pressing play on a deck.
From the help on this option:
Quote :
The recording will automatically start as soon as you press play on a deck
geposted Wed 29 Aug 18 @ 10:23 am
thanks for clarification.
geposted Wed 29 Aug 18 @ 10:25 am
