Good day!!
Looking for anyone that can lead me to a skin for an American Audio DP-2 board...
Thanks for the help!! Jay
geposted Sat 01 Sep 18 @ 3:04 pm
have you tried here https://www.virtualdj.com/addons/controllers.html
geposted Sat 01 Sep 18 @ 3:22 pm
Any skin will work.
There is no need to have a skin for a particular controller (presumably you mean a skin that looks like the controller).
All those knobs and buttons you have right there in front of you - they don't need to be on the screen. You have real ones!
geposted Sat 01 Sep 18 @ 6:47 pm
Hi, i use the default skin since 4 years, it works well , there is no custom skin for the DP2 with VDJ,
It’s a native mapping ,
Good luck
GK
Good luck
GK
geposted Sun 02 Sep 18 @ 7:20 pm
I saw a few years ago some one was working on an accurate skin for the DP-2. in 2012 djBAV said it was in the works. Thought it might be done....
geposted Wed 05 Sep 18 @ 9:43 pm
