Forum: Wishes and new features
Topic: 'fxProcessing' as VDJScript
grennoPRO InfinityMember since 2012
Is there any possibility of getting the 'fxProcessing' option as a VDJScript boolean?
Essentially it'd be great to map this to a button for easy toggling!
geposted Sun 09 Sep 18 @ 12:22 am
The scripts are:
setting 'fxProcessing' 'pre-fader'
and
setting 'fxProcessing' 'post-fader'
... or maybe for a toggle:
setting 'fxProcessing' 'post-fader' ? setting 'fxProcessing' 'pre-fader' : setting 'fxProcessing' 'post-fader'
geposted Sun 09 Sep 18 @ 11:05 am
ah great!
didn't realise there was a setting action!
Cheers!
geposted Mon 10 Sep 18 @ 1:21 am
RanikiPRO InfinityMember since 2018
Klausmogensen thanks for that script.
I've tried applying it to one of the default skin custom buttons, and the button light does not toggle on and off - so no way of knowing what state the fxprocessing setting is in... any ideas? :-)
geposted Wed 06 Mar 19 @ 12:49 pm
You should be able to do a toggle on a custom button, including light using something like:
setting "fxProcessing" "Post-fader" ? on & setting "fxProcessing" : off & setting "fxProcessing"
geposted Wed 06 Mar 19 @ 2:58 pm
... and if you want it on 2 custom buttons, you can do something like
setting "fxProcessing" "Post-fader" ? off & setting "fxProcessing" "Pre-fader" : on
and
setting "fxProcessing" "Pre-fader" ? off & setting "fxProcessing" "Post-fader" : on
geposted Wed 06 Mar 19 @ 3:02 pm
Great that worked. Thanks Klausmogensen.
I had tried playing around with 'on' scripts etc but hadn't quite got the syntax right!
geposted Wed 06 Mar 19 @ 10:08 pm
