Hi,
I need help and advise.
1) Ever since I use the 64bit version the program took a longer time (about a minute) to open & windows 10 notified with an error message.
After the program open, whenever I try to open certain filter folders the library just froze for about a minute. It's annoying & frustrating to me whenever happened in the middle of my set. Speed is an essence in our line of duty.
2) Asio setting in my SX3 are unable & I have to use wasapi. This also happen to DJM-850 (Already reinstall the driver twice to make it work). Some hardwares work better on Asio then wasapi especially on scratching mode.
These 2 problems also affected the 32bit version.
Kindly advise me ASAP. I rely on vdj to work flawlessly.
My laptop is Lenovo Y500
geposted Sun 09 Sep 18 @ 3:00 am
Sorry my bad, the main topic and issue is on virtual folders NOT filter folders. Apology
geposted Sun 09 Sep 18 @ 3:10 am
What columns do you have enabled in the VDJ browser? Anything that reads the file dates?
Where are your tracks stored (internal or external drive)?
geposted Sun 09 Sep 18 @ 6:25 am
Perhaps your virtual folder has bad links in it?
geposted Sun 09 Sep 18 @ 6:42 am
ALL MY TRACKS VIDEO & AUDIO ARE STORED INTERNALLY.
NO PROBLEM ON FILE DATES.
HERE'S THE COLUMN IMAGE. (ONLY THE EVENT MUSIC FOLDER GAVE NO PROBLEM, I HAVE TESTED THE REST ARE OK
geposted Sun 09 Sep 18 @ 11:22 am
I HAVE DELETED ALL THE BAD LINKS TRACKS SUCH AS MOVED OR DELETED UNWANTED TRACKS.
geposted Sun 09 Sep 18 @ 11:24 am
Please stop SHOUTING. Type normally (lower case).
The picture you posted is folder list, not the browser columns.
I asked if you had the file date column displayed, because it will slow VDJ down if you do.
geposted Sun 09 Sep 18 @ 1:31 pm
I didn't know that typed in capital is shouting. Look offended to you? I just want to differentiate between my question & your answers.
I didn't display file date column.
geposted Sun 09 Sep 18 @ 2:25 pm
Gratitude in advance for your help & advise.
geposted Sun 09 Sep 18 @ 2:31 pm
