Topic: Virtual DJ Licence!!!
DJGLYControlleristMember since 2014
Hello!
I have a problem! I had PRO Subscriber licence! it ended 9 september! i bought new licence for numark mixtrack platinum controller home use! why my Pro subscriber is not gone yet? it says its 0 days left and new licence dont show up? does it show up next day or when then ? i see it is exists on my account i cancelled my monthly payment for PRO user-! when i see numark mixtrack platinum licence i payed 112 eur for it !!!!!
geposted Mon 10 Sep 18 @ 12:41 am
Looks like everything is fine with your license, you should see the Plus license in VirtualDJ under Options->Licenses
geposted Mon 10 Sep 18 @ 6:56 am
hi , thnx for answer , and yes i see it , didnt looked it carefully! so it will be working !
geposted Mon 10 Sep 18 @ 7:39 am
https://www.virtualdj.com/users/licenses.html
its shows me like this ! i ordered numark mixtrack platinum , license , and ended up pro subscriber , but it shows im still pro subscriber , it should be ended @ 9 sept , but its 10 th sept now !!!
geposted Mon 10 Sep 18 @ 7:47 am
There is a grace period of a couple of days, so it might take a few days before it stops.
geposted Mon 10 Sep 18 @ 8:09 am
ok, thnx for letting know...hav a great week to you.
geposted Mon 10 Sep 18 @ 8:11 am
LarchyPRO InfinityMember since 2018
Hey guys,
I purchased a controller second hand and then downloaded the vdj software and purchased the pro licence on subscription. I take it this is all good. I keep seeing pro licences that are going for really cheap, are these legit?
geposted Tue 09 Oct 18 @ 1:12 am
Where are you seeing them?
The only legitimate place to buy a license is here.
geposted Tue 09 Oct 18 @ 7:07 am
Seeing them on eBay, can't imagine then being legit though
geposted Tue 09 Oct 18 @ 7:14 pm
They are not. Atomix have a piracy department but I don't know how effective it is are there are always dodgy copies on eBay UK.
geposted Tue 09 Oct 18 @ 8:11 pm
tengo un problema con una licencia de un controlador un amigo me ha vendido una dj consola mk4 la ha utilizado dos veces y esta nueva pero no se acuerda del usuario que tenia nin el correo que utilizo y no le puede dar de baja a la licencia
tambien queria preguntar si va bien con windows 10 que me esta dando problemas el virtual me reinicia el ordenador y no se a que es debido
geposted Tue 09 Oct 18 @ 8:32 pm
tambien no me va bien el virtual dj de la mk4 que me reinicia con windows 10 en un portatil
geposted Tue 09 Oct 18 @ 8:35 pm
How to cancel my virtual pro monthly lincence
geposted Tue 21 Jan 20 @ 3:44 pm
Stop paying.
geposted Tue 21 Jan 20 @ 3:59 pm
