Hello! I use a ddj-sz and ddj-rz. My sz has this function: KEYLOCK. Press this button to "lock" the track's pitch to its original key. The track's tempo will remain at the speed designated by the Pitch Fader. Press and hold the button for more than 1 second to smoothly reset the Pitch of the track to zero (original tempo). Hold SHIFT and then press this button to cycle through the available pitch ranges.
my rz has this function: MASTER TEMPO. Press this button to "lock" the track's pitch to its original key. The track's tempo will remain at the speed designated by the Pitch Fader. Hold down SHIFT and press this button to cycle through the available pitch ranges (6%, 10%, 12% and 100%)
I would like to make my rz do exactly what my sz does. I would like to know if this is possible.
Both buttons are in the same location. I want the RZ to Press and hold the button for more than 1 second to smoothly reset the Pitch of the track to zero (original tempo).
geposted Tue 11 Sep 18 @ 9:02 pm
MASTER TEMPO :
and perhaps its led blinking while pitch is resetting....
LED_MASTER_TEMPO :
holding 1000ms ? pitch_reset : key_lock
LED_MASTER_TEMPO :
pitch_reset ? blink 500ms : key_lock
geposted Tue 11 Sep 18 @ 9:23 pm
thank you!
geposted Wed 12 Sep 18 @ 3:05 am
Do i just cut and paste this? Sorry, I am a noob with scripting
geposted Tue 18 Sep 18 @ 10:38 pm
Yes paste the above to the Action field of the related Key
http://www.virtualdj.com/manuals/virtualdj/settings/controllers/index.html#custom%20mapping
geposted Tue 18 Sep 18 @ 11:19 pm
thank you so much DaD!
geposted Wed 19 Sep 18 @ 7:12 pm
