Topic: Question About VDJ 8.3 64 Bit Version
I am running the 64 bit version next to the 32 bit version. If there is an update, will it update both versions?
geposted Fri 14 Sep 18 @ 6:48 pm
If you run the 64-bit version, the 64-bit version will be updated, and if you run the 32-bit version, the 32-bit version will be updated.
geposted Fri 14 Sep 18 @ 6:55 pm
Ok. So If I get an update on the 64 bit version, I will have to run the 32 bit version to update that one too.
Got it; thanks.
geposted Fri 14 Sep 18 @ 7:19 pm
