I had a sample added to my sidelist (a .vdjsample file) and when I right-click it the only options are "sample editor" or "file operations", there is no "remove" option to clear it from the sidelist.
Is this a bug or are there other ways of taking a file off the sidelist?
geposted Tue 25 Sep 18 @ 12:21 am
Select the sample in the sidelist using your mouse and hit the del key on your keyboard.
geposted Tue 25 Sep 18 @ 1:23 am
Thanks
geposted Thu 27 Sep 18 @ 4:20 pm
I love drag and drop in VDJ7. Hope bone day they add to 8
geposted Sun 07 Oct 18 @ 8:45 am
I can drag and drop, what exactly are you trying to do.
geposted Thu 11 Oct 18 @ 11:06 pm
Probably either dragging a song off a deck to remove it or drag to move between playlist and sidelist. Neither has been implemented in v8
geposted Thu 11 Oct 18 @ 11:29 pm
kradcliffe wrote :
...or drag to move between playlist and sidelist. Neither has been implemented in v8
Off topic, but useful to know...
Drag a song from Automix and move it over the Sidelist button (at the bottom of the Sideview). Wait for 2-3 seconds (with mouse-click still down), Sidelist opens up, then u drop song to Sidelist ;) Works the other way too.
However, it actually "copies" the track, not removing from the previous list.
geposted Fri 12 Oct 18 @ 7:02 am
Correct, but there should be an option as to whether dragging a track between lists either moves them or copies them.
Really can't be that difficult to implement.
geposted Fri 12 Oct 18 @ 12:26 pm
