Thanks for these great new karaoke features!
However, the default karaoke skin which normally shows the title, artist, and cover of background music during karaoke mode does not do so if you enable karaokeDualDeck. I suspect get_karaoke_background_song isn't karaokeDualDeck-aware.
v8.3 b4591 (early access enabled, if that makes a difference)
geposted Fri 28 Sep 18 @ 6:15 am
It is displayed on the karaoke deck currently, so you may need to disable automatic video crossfader and move the video crossfader to the karaoke side to see it.
geposted Fri 28 Sep 18 @ 7:55 am
