Ran into a problem, I can't remove a sample file from a virtual folder, Only option is delete and don't want to delete a sample I actively use.
How do I remove this sample file from a VF?
Windows 10 Ver. 1803
VDJ v8.3 b4537
Thanks
VDJ v8.3 b4537
Thanks
geposted Fri 28 Sep 18 @ 12:43 pm
Press the delete key on your keyboard
geposted Fri 28 Sep 18 @ 12:46 pm
...But I Don't want to delete the file, I just want to remove it from the virtual folder it's in..
Thanks..
Thanks..
geposted Fri 28 Sep 18 @ 2:27 pm
I think you need to read the VDJ 8 manual - particularly the part about virtual folders.
"A virtual folder contains a collection of shortcuts to the files and not the actual files themselves.
geposted Fri 28 Sep 18 @ 2:42 pm
That removes the file. It doesn't physically remove the file from the system.
It's not possible from within VDJ to delete a file physically with a single key press (although some people, me included, wish that it would be possible).
geposted Fri 28 Sep 18 @ 2:45 pm
Okay, I was able to remove the file with the keyboard delete key from the folder only..
Thank You for the help..
One confusing thing I will say is that when you highlight multiple file names within a virtual folder and right click you have the option to remove, but if you have a sample file contained within, the option is to delete as per my first post..
geposted Fri 28 Sep 18 @ 2:55 pm
