Topic: Move issue
I have a MacBook Pro mid 2012 with High Sierra + Virtual 8.2
Can anybody help my?:
Virtual don't move files to a external hdd or Stick etc
It is let my move only to the same hdd(internal in my situation).
To copy is working fine.
please anybody help
thank's
geposted Tue 02 Oct 18 @ 3:14 pm
Are you trying multiple files each time ? Can you check if it works with a single file ?
geposted Tue 02 Oct 18 @ 9:08 pm
maybe he is running a old build with some bug he does say it's 8.2
geposted Tue 02 Oct 18 @ 11:19 pm
I try single, i try multiple. not working.
I have VDJ 8.3 (4537)
geposted Fri 05 Oct 18 @ 9:33 am
Perhaps you need to check write permissions for your external HD
Are you trying moving with right click Files Operations ? Or mouse ? Can you provide exact steps to reproduce here ?
geposted Fri 05 Oct 18 @ 6:45 pm
