Or is there a simple effect I can download like scrolltext 2. Worked great in VDJ7 but all the text is upside down in version 8.2
geposted Fri 05 Oct 18 @ 2:35 am
Did you already try TellyVisuals? You have that option there and working like a champs
geposted Fri 05 Oct 18 @ 3:42 am
No I didn't try it. It seams like a learning curve to understand. I just want something I already know tonight or simple steps
geposted Fri 05 Oct 18 @ 3:49 am
If you need it tonight, just go back to VDJ 7 temporary, and you will do it fine
geposted Fri 05 Oct 18 @ 3:56 am
I understand but i don't wanna stop the beat. Playing in a club
geposted Fri 05 Oct 18 @ 3:57 am
Ok, I'm sorry to hear that, maybe somebody else can help you, so far they didn't fix that problem with VDJ 8 text
geposted Fri 05 Oct 18 @ 4:04 am
TellyVisuals doesn't really have a huge learning curve. and speed adjustment for scrolling text and customizing it on the fly in TellyVisuals is really easy. I use it all the time for adding birthdays and whatnot.
geposted Fri 05 Oct 18 @ 7:29 am
