Hi again
Back once again with the same problem.... After 2-3 hours play at the Ddj 1000 controller, suddenly it starts to distort... The distortion and clipping is permanent...
Things that i have checked under the problem: Changed the latency setting up and down.... Diddent worked... then i changed the driver to wasapi.... Diddent work either..
My specs are way above the requirements for this controller... I get same results on my Win 7 pro pc, and same results on my win 10 pc..... I think the problem started with the new build b4591-4592..... I ran a wedding gig date 15-9-2018 with the controller on my win 10 system, and there was no problem....
Status: Now im checking an older build b4204 with the controller, maybe it works ??? i Played a gig last night on my Denon Mc6000mk2 win7 pro B4204, Had Zero isues
geposted Sat 06 Oct 18 @ 8:26 am
