Hi
im having issues connecting my laptop to my nxs2 decks? ive tried the usb interface but after a while it seems to stop working on one deck? i cant scroll through track but can only load via manually loading the deck via my laptop? is there a way i can connect via the ethernet port as it does if i use the rekordbox software? if so how can i acheive this? if not then can it be possible to make this happen in a new update?
regards
regards
geposted Mon 08 Oct 18 @ 6:01 pm
