Hi everybody,
suddenly i do not anymore have the possibility to spin back decks. At first it was only deck 2, but now it´s all of them.
It´s not the -effect-, I mean that i can´t move decks back- or forward faster by using mouse or turntable on mixer.
Please help!
Please help!
geposted Tue 09 Oct 18 @ 7:52 pm
You need to ensure that your jog wheels are in the correct mode - see manual for details.
geposted Tue 09 Oct 18 @ 8:54 pm
turn off smart scratch its in options and active vinyl mode
geposted Tue 09 Oct 18 @ 9:46 pm
What happens when you backspin ? No sound, no backspin ? Are you able to touch the jog and stop/scratch the track ?
Software wise, other than making sure Vinyl mode is enabled and your touch-sensitive jogs work (you can scratch), these are the settings you should check as well.
geposted Wed 10 Oct 18 @ 3:58 am
Thank you all very very much!!!!
It was the non activated vinyl option (shame on me)
Now the problem is solved
YOU´RE GREAT!!!!
YOU´RE GREAT!!!!
geposted Wed 10 Oct 18 @ 5:53 pm
