Topic: Pro License on Dj Controllers
When purchasing a Pro License, I know you can't transfer license to another person, but can you change controllers when you upgrade?
geposted Fri 12 Oct 18 @ 1:38 pm
The Pro licence will work with all supported controllers instantly so no need to change anything.
You can also use multiple controllers at the same time if you so wish.
geposted Fri 12 Oct 18 @ 1:51 pm
