Have 2 Sx3 and can not get the audio sound card to show. Using 2017 MacBook Pro. Latest version of vdj8. Up to date on Mac updates. Any ideas
geposted Fri 12 Oct 18 @ 6:32 pm
did u install the mac drivers? https://www.pioneerdj.com/en-us/support/software/controller/ddj-sx3/
also read here page 5 http://docs.pioneerdj.com/Manuals/DDJ_SX3_DRI1542A_manual/?_ga=2.166383545.682389393.1539371856-2055046145.1538607944&page=4
geposted Fri 12 Oct 18 @ 7:20 pm
I did install and I am not having the problem in the manual. I have no idea what is going on.
geposted Fri 12 Oct 18 @ 9:24 pm
For some strange reason your uploaded stats show...
coreaudio=PIONEER DDJ-SX2
,meaning that a driver with the above name has been used in your Audio Setup. Is this the name you see in the drop-down list when you try to select a sound card in Audio tab of VDJ ?
Please make sure you are on the latest Build (currently 4592). There was a fix at some point.
If still have issues with latest Build...then please do the following...
- Open VDJ, goto Settings-->OPTIONS tab
- Search for the setting CreateMidiLog and set to Yes
- Close VDJ.
- Make sure your DDJ-SX3 is connected and powered on
- Open VDJ.
- Wait for a few seconds to initialize
- Close VDJ
- Post there the content of the Log Report.txt file you will find in /documents/VirtualDJ folder
- Close VDJ.
- Open VDJ.
- Close VDJ
geposted Fri 12 Oct 18 @ 9:31 pm
Connot get my ddj-sx3 soundcard to show on virtual dj even after i download drivers
geposted Sun 15 Dec 19 @ 3:14 am
Since you're using a MAC, please read this carefully:
https://www.pioneerdj.com/-/media/pioneerdj/downloads/other/troubleshooting/troubleshooting_highsierra_003_e.pdf?la=en&hash=F926BC62D3C490CB95D98DE599E8D04797D2C6F8
geposted Mon 16 Dec 19 @ 1:54 pm
having same problem please help
geposted Thu 29 Jul 21 @ 9:15 pm
