Topic: Reloop RP8000 Weird Problem
So, explain this one if anyone knows. Using a set of Reloop RP-8000's with a Pioneer S9 Mixer.
1. Left turntable: All pads work perfectly fine and control the left deck in VDJ, except the pitch control. It controls the right deck in VDJ
2. Right turntable: Same thing...all pads work and control the right deck except the pitch. It controls the left deck in VDJ
So basically everything works the way it should except only the pitch, which is controlling opposite virtual decks. The S9 pads and everything work the way they should and control the correct sides.
What would make ONLY the pitch control opposite sides? Could it be something weird in the way the MIDI signal is sent? I looked at the mapping and it's not mapped to individual decks. It's just the standard pitch mapping that comes on everything.
geposted Mon 15 Oct 18 @ 12:02 pm
geposted Mon 15 Oct 18 @ 2:25 pm
Yeah, latest firmware and default mapping.
geposted Mon 15 Oct 18 @ 2:35 pm
Yeah Ive never had this happen with mine.....
geposted Tue 16 Oct 18 @ 12:21 am
