Topic: DJM 400 mixer not working with VDJ and CDJ 400
Hi, i have just downloaded VDJ and plugged in my set up, CDJ 400's with DJM 400 mixer. I have got the CDJ's working perfectly but have no response from my mixer. What could I be doing wrong or not have set up correctly?? Please help!
geposted Tue 16 Oct 18 @ 12:44 pm
What do you mean by "no response"? What are you expecting and what's happening instead?
How have you got everything set up?
You should (IMO) be using VDJ in 'external mixer' mode, with each VDJ deck's audio going to a separate CDJ-400, then feeding the RCA audio outputs of each CDJ into each channel of the mixer.
If the mixer is on, and the audio is coming from VDJ through the CDJ-400s then I see no reason why the mixer shouldn't output audio.
geposted Tue 16 Oct 18 @ 6:20 pm
pseftPRO InfinityMember since 2009
you should know, you can't control DJM 400s with vdj... you need either HID or USB connections and this mixer don't have it
geposted Fri 19 Oct 18 @ 7:15 pm
Hello, i need skins for CDJ-400 players, it will work on windows only or also for mac? DJM is an anolog mixer so i think you can`t controled by vdj program
geposted Thu 03 Jan 19 @ 7:45 pm
