Topic: line input not working
Hello,
I am trying to stream tv sound via the internet and have the sound go thru a deck. I am running with a ddj-sb2 on windows 7. I have the Home PLUS License for ANALOGMIXER and Home PLUS License for DDJSB2. I have had this working before but my settings got messed up and i cant get back to how it was. Can any one help me please.
geposted Fri 19 Oct 18 @ 4:17 am
apart from the obvious Master->DDJSB2(Chans,12) and Headphones->DDJSB2(Chans3,4), you should add a line with linein..
linein -->TheSoundCardWhereTheStramisInput(chans-probably 1,2)
So the question is, to which Sound-Card and to which Input of it , is the Stream Audio signal connected/inserted to ??
geposted Fri 19 Oct 18 @ 1:16 pm
Here is what i have so far.
master is pioneer DDJ_SB2 ASIO Channel 1 and 2
Headphone DDJ_SB2 ASIO Channel 3 and 4
it wont let me press the input line button
geposted Fri 19 Oct 18 @ 7:19 pm
don't understand this. Are you referred to the Line Inputs button at the top-right tab of VDJ Audio Setup ?
What happens if you press it ? It should add a couple of lines, if not, try the Mic button, then edit the added line with linein instead of microphone.
But still u need to fill the input of your built in sound card with the stream in order VDJ to get it from the added linein
geposted Fri 19 Oct 18 @ 11:28 pm
