Topic: Moving Pads Pages
Is there a way to change the order of the pads on Pad Editor? Adding the Index extension and I would like to change the order to give me access to my most used Pads on page one.
Check the manual and forums. No luck.
TIA.
geposted Fri 19 Oct 18 @ 8:44 am
Do you mean order in the drop down? Or what a spcific pad page does?
geposted Fri 19 Oct 18 @ 8:49 am
Order in drop down.
I'd like to be able to change what Pads appear on the Index pages to suit my needs.
geposted Fri 19 Oct 18 @ 8:50 am
Now I get it - it's the downloadable add-on pad-page named index you mean - I forgot about that one :)
I'm not sure about the order, except hiding the ones you don't use to get to the ones you use
But you can simply create your own index pad page if you like
I did a video about it a while back before the downloadable add-on was released:
geposted Fri 19 Oct 18 @ 8:57 am
Got it. I had one made, but thought it would be great to change them without scripting.
Perhaps a wishlist item!
Thanks as always. Had a feeling you would respond first!
geposted Fri 19 Oct 18 @ 8:59 am
