When I'm in Slip mode, and I press the pause/play button twice, the track doesn't slip. Rather, it stops and continues from where it stopped.
this is not the same as in Serato.
In serato, once in slip mode, you can press the play/pause button freely without the track going off beat.
Help, do I need to set anything?
NOTE: Every other thing in slip mode works well, scratching, cue and other effects. just the pause/play button doesn't obey the rule.
geposted Fri 19 Oct 18 @ 5:22 pm
iamDJvirus wrote :
... this is not the same as in Serato
This was never the sole reason for VDJ to follow something that others do! ;)
I understand that combining Slip mode with scratching, hot cues, loops etc provide some kind of mixing technique without losing the beat, but can you find a good reason why and in what case having the play/pause working that way in slip mode , would serve any mixing purpose/technique ?
If all you want is to mute sound and continue in beat, then why don't you just set its volume to zero and restore back when u need ?
geposted Sat 20 Oct 18 @ 1:15 am
maybe he is trying to make a break effect?
geposted Sat 20 Oct 18 @ 1:23 am
No, this is a bug in serato - pause should always pause, it's really has nothing to with slip mode
What you may want in VDJ could be slipbrake8:
https://www.virtualdj.com/plugins/index.html?category=effects&search=slipbrake8
geposted Sat 20 Oct 18 @ 9:11 am
Yeah... I'd like a slip mode pause. I want to do breaks that way and have them stay in sync. Not because of Serato but because that's how I'd like to do them.
geposted Sat 20 Oct 18 @ 6:07 pm
so, quite an old post but anyway...
i'm super noob at this but i was fiddling around with this concept and i wrote this script:
slip_mode? play? slip & pioneer_play : slip off & pioneer_play : slip off & pioneer_play
it seems to work as intended if you're only going to use global slip for this purpose: basically it checks for slip_mode (which I have already mapped to a button on my controller) and if true it activates global slip right after pause, and deactivates it on play..., if false it behaves normally (and it sets global slip off just to be sure).
So I mapped this to my play/pause and I'm a happy guy =)
As I said, i know nothing about scripting and this was a lot of trial and error, if anyone knows how to better implement this, please share!
cheers
PS: i just noticed that the play button LED wasn't functioning correctly, so I had to manually map the LED_PLAY/PAUSE to pioneer_play, and it now behaves correctly
cheers
geposted Thu 06 Aug 20 @ 12:00 pm
@deejaypandaa Normally you'd just set your scratchTime to 0 in the settings, enable slip, and put your hand on the platter (to stop it) to get the same effect.
The VDJScript command for touching the platter is
touchwheel_touch
geposted Fri 07 Aug 20 @ 5:04 pm
This is not learning other software. This is a mixing skill function. I don't understand why VDJ can't add global slip, why is it so stubborn? Many people want to add this feature, why not?
geposted Sat 26 Sep 20 @ 12:53 pm
The great thing about VDJ is that you can script many things without Atomix having to implement it for you.
I asked about this here and it works really well!
geposted Sat 26 Sep 20 @ 6:31 pm
