Topic: "Pressure Action" controller pad mapping
Ohm_RSAPRO InfinityMember since 2006
How do I map pad pressure to an fx slider in the "Pressure Action" in pads editor?
E.g move the fx slider based on the pressure applied to the pad
geposted Tue 30 Oct 18 @ 5:02 am
The Pad Pressure tab in the Pads Editor, holds the (optional) action for a Pad that supports velocity (how hard you hit the Pad) and its action is usually related to the action of the Pad its self. E.g. when triggering a Sample, and the Pad supports velocity, you may want to control its Volume according to the strength the Pad is pressed (initially or constantly, depending on which type of velocity the hardware supports). another example would be to assign the Velocity to control a Wet/Dry Parameter of an effect, so that you apply the Effect when the Pad is triggered but also adjust its Strength according to the pressure on the Pad.
But again, this is up to the Hardware.
If your Hardware supports Velocity, then in your example the Pad Pressure tab should have an action like effect_slider X , where X is the number of the FX Parmeter that you wish to control when the Pad is pressed.
If you dont know if your Hardware is offering Velocity, then goto VirtualDJ Settings->Controllers tab, select your Hardware and press a Pad. On the right side of the same window, known as the "Key Learn" section, you will probably see the Pad key e.g. HOTCUE_PAD1 name coming in the list. If pressing the Pad, an additional key is coming up, such as HOTCUE_VEL_PAD1 or similar, then your Hardware probably supports that.
Which Hardware- controller do you use ?
How is your Pad (Action tab) assigned ?
geposted Tue 30 Oct 18 @ 12:48 pm
Thank you, it's a Pioneer DDJ-RR.
Will test this evening and let you know
geposted Tue 06 Nov 18 @ 6:14 am
The DDJ-RR doesnt have velocity Pads, so whatever action you assign to the "Pressure" tab, it wont have any impact to the behavior of the Pads.
geposted Tue 06 Nov 18 @ 1:10 pm
Ah ok, is there way to change the value of a silder gradually while the pad is pressed then?
For example move slider +25% every beat while the slider is pressed?
geposted Mon 19 Nov 18 @ 4:36 pm
Did we ever find out how to increase/decrease the strength by holding down a key,?
geposted Thu 09 May 19 @ 5:42 pm
repeat 200ms & effect_slider 1 1 +3%
geposted Thu 09 May 19 @ 11:15 pm
