ho un pc che ha windows 10 e ho un mixer vecchio e quindi uso un virtual dj vecchio perchè non è compatibile con virtual dj 2018 e mentre mixo mi fa uscire da virtual dj e mi dice di aggiornarlo c'è un modo per farlo andare?
geposted Fri 02 Nov 18 @ 5:48 pm
Please post in English or use the Italian forum
Which controller are you trying to use with VirtualDJ 2018 and doesn't work ?
There is no mixer/controller that works in old VirtualDJ versions but not in VirtualDJ 2018, with the exception of Serial port connection (e.g. DAC2) but i think it's not the case for you (?).
If your controller came with an old OEM/Limited Edition of VirtualDJ and wish to use with a more recent version and/or get more features, then either you will need to keep and use what you have, or purchase a Pro/Plus license to use with VirtualDJ 2018. http://www.virtualdj.com/buy/index.html
geposted Fri 02 Nov 18 @ 7:48 pm
