Forum: Old versions
Topic: NS7 Controller
mburgosPRO InfinityMember since 2007
Good morning to all. Hopefully some can help me and has experience the same issues I have with the NS7 controller. Im currently using a dell lap top and it works fine. I would love to use my Mac Pro but its running an OS system 10.13.3. The driver that is on the Numark support site is a 10.12 v3.3.11 I am using virtual dj with this controller but I have been experiencing problems after a little while in my mix. I start to get some static feedback and sounds horrible and I have to stop my mix shut down and start over but after a little while I continue to have the same issues. I know I'm using a old controller but it works fine until recently. A friend told me that it may be a software issue and if it is does anyone know or has had an issue like mine and if so what can I do to fix the problem. You help is greatly appreciated. Thanks to all you fellow DJs and rock those mixes!!!!
geposted Sat 03 Nov 18 @ 12:53 pm
And this static sound goes away if you turn off motors (vinyl mode) ?
geposted Sat 03 Nov 18 @ 1:18 pm
Thank you DJDad. Going to shut down motors on vinyl. Thanks
geposted Tue 06 Nov 18 @ 3:15 am
