Anyone know how to setup OBS to work with VDJ with video with only one screen?
It chokes if you open the video preview and tell OBS to use that plus the screen it picks will then be too small anyways. When you do use it, when you actually start broadcasting, it screws up the preview window.
Then there's the issue of you can't map the sound at all -
VDJ's built in streaming does NOT work with CHEW.TV anymore while OBS works fine from the same machine.
geposted Mon 05 Nov 18 @ 5:11 pm
