Hey there,
I have the Pioneer DDJSR2 - at the top there are three FX knobs but I can only select the function for the first.
Is there a way to map additional FX to the other knobs?
Many thanks!
Many thanks!
geposted Tue 06 Nov 18 @ 4:31 pm
Phillip_Hill wrote :
Hey there,
Many thanks!
Many thanks!
Usually it depends on if you have selected multi fx in VDJ (by clicking the effect section header)
Looking at the DDJ-SR2 manual for VDJ, it seems to also be the case for this unit:
http://www.virtualdj.com/manuals/hardware/pioneer/ddjsr2/layout/effects.html
geposted Tue 06 Nov 18 @ 4:45 pm
