I cannot for the life of me get VirtualDJ 2018 to work. I have two hard drives and i had it installed in my secondary. So anytime i tried to run it, it open for like half a second then close then open for half a second again then close for good. Then i installed it to my C drive and it would do the same thing execpt on the second time it would just stay open frozen instead of closing. Can somebody please help me? I've even tried older versions, the only thing that works is VirtualDJ 7 and I hate 7 so much.
geposted Thu 08 Nov 18 @ 10:55 am
We'll need more info than that.
OS ?
Computer specs ?
Assuming that you use Windows, VirtualDJ can run form anywhere on your hard drive(s).
However it requires that you have sufficient access rights on system "Documents" folder
Also make sure that your graphics card drivers are up to date
OS ?
Computer specs ?
geposted Thu 08 Nov 18 @ 12:10 pm
I figured it out! It was rivatuner making it crash. After i closed rivatuner i didn't have any problems.
geposted Fri 09 Nov 18 @ 2:19 pm
