VirtualDJ does not start!
A message says Warning:Start up of Browser- Tree is taking a long time.
What can I do??
What can I do??
geposted Fri 09 Nov 18 @ 3:58 pm
You can wait - it should eventually start up. If you are impatient you could rename you settings.xml file and restart VDJ. But you will lose your settings etc.
You likely closed VDJ with a very large folder opened in the browser and/or you have the file date field showing in the browser view. The file date causes VDJ to check each file in the folder.
Anyone else with other ideas?
geposted Fri 09 Nov 18 @ 10:38 pm
