So not to drag this out, I bought a 4k MSI Laptop so I could retire my Alienware 17 i7 256ssd + 2tb hdd + GTX460, that I used for 6 years (workhorse), never any problems with video glitching. The problem is that I cannot disable the integrated graphics card and force it to use the other card. I have tried settings in VDJ and in windows graphics settings. I play and mix music videos and to lose this over something so minor is pathetic. Any Help???
geposted Sat 10 Nov 18 @ 9:52 am
Selecting the NVidia cpu in the nvidia control panel before launching VirtualDJ should be enough.
What makes you think VirtualDJ is not using the nvidia?
Also, for improved video performance, you could give the 64-bit version of VirtualDJ a try:
https://www.virtualdj.com/forums/225388/General_Discussion/VirtualDJ_2018_Windows_64-bit_beta.html
geposted Sat 10 Nov 18 @ 10:21 am
Thank you I will try the new version.
geposted Sat 10 Nov 18 @ 5:16 pm
