Can you tell me which file holds the information for where VDJ is to save settings etc.
For some reason, VDJ has started to save to my one drive instead of documents. I need to find what tells VDJ to save to what location so I can edit in Notepad++ and get it saving to the right place.
Hope that makes sense.
geposted Sat 10 Nov 18 @ 9:36 pm
Virtual DJ save most of it files in MyDocuments/VirtualDJ
However if you have music on an external hard drive then the database for those files will be stored on the external drive.
This means you could plug that drive into a different machine and Virtual DJ would still read the tags/cues/loops etc.
I would not advice editing anything in Notepad++ unless you know exactly what you want to achieve as you may end up corrupting the database completely.
geposted Sun 11 Nov 18 @ 12:38 am
