Topic: Changing pitch messes up playing loop length
VDJ v8.3 b4592 Win 10 Pro 64-bit
Steps to reproduce problem (for a give deck):
1. Load a track into a deck
2. Press PLAY button
3. Ensure "Master Tempo" is checked for the deck (this really should be labelled "Key Lock")
4. Set pitch fader to the 0 (centre) position
5. Set loop length = 2 beats
6. Press AUTO LOOP button to start playing the loop
7. Now, rapidly drag the pitch fader all the way down with the mouse
Expected result: The track tempo changes but the loop continues to play 2 beats exactly.
Actual result: The loop length is reduced to 1 beat.
I can reproduce this consistently on all decks. Thanks! :)
geposted Wed 14 Nov 18 @ 5:31 am
Doesn't change the loop length for me. What is your pitch range set to?
It was set to 100% (I know this is not very sensible in a practical situation but I'm just exploring the software). Anyway, after a restart of the software I can't reproduce it anymore, even with the pitch range set to 100%. If It happens again I'll come back. I'm still not familiar enough with the software to know if I'm doing something wrong.
