When pressing the play button, the song takes around six seconds to get up to speed. How do I set it so there is no delay. This is very frustrating.
geposted Thu 15 Nov 18 @ 8:20 am
Check your settings.
Set rampStartTime, rampStopTime & rampScratchTime all to ZERO
geposted Thu 15 Nov 18 @ 9:36 am
Are you using a controller?
If so, check if you have a vinyl speed control on it. It may need turning back down to zero once again.
I get caught out with this sometimes on my Pioneer XDJ-RX when i use it for the stop brake function. Often forget to set it back to zero and i get the same effect as you are describing.
geposted Thu 15 Nov 18 @ 10:26 am
On XDJ-RX you can remap your knob to "brakespeed" if you wish..
This way it will control only the time it takes to stop the deck after pause, and not the time it takes to speed up after play... (which is startupspeed action)
geposted Thu 15 Nov 18 @ 11:52 am
I have the xdj rx2
geposted Thu 15 Nov 18 @ 3:53 pm
BrianSTC wrote :
I have the xdj rx2
Then I think it's just the "vinyl speed adjust" knob you need to turn
geposted Thu 15 Nov 18 @ 4:25 pm
I may just do this, never use it to adjust start up time. Thanks phantom
geposted Thu 15 Nov 18 @ 9:29 pm
BrianSTC wrote :
I have the xdj rx2
Yes, there is :) Item 39:
http://www.virtualdj.com/manuals/hardware/pioneer/xdjrx2/layout/deck.html
geposted Fri 16 Nov 18 @ 1:11 am
Thanks. That solved it
geposted Fri 16 Nov 18 @ 8:56 am
