hi all
is it possible to make a filter folder
with all the songs that are not in a certain virtual folder?
geposted Fri 16 Nov 18 @ 9:30 am
No
geposted Fri 16 Nov 18 @ 12:44 pm
the only way i can think of, but will not be automatic, is to select all files in that Virtual folder and provide some unique text to a spare/unused DB field such as "User1", "User2" or "label"
then you could use a filter like label contains text
but each time you add something in that Virtual folder, you will also have to edit its extra field with the same unique text
geposted Fri 16 Nov 18 @ 1:25 pm
