Hey am I missing something or is it not possible to AUTO sync the" beatkeeper" of 2 tracks by pushing a button? It seems that it cannot be scripted?
Do scripts only support ms and s? No chance for bpm relative timings (bars etc)?
geposted Mon 19 Nov 18 @ 1:46 pm
no one has the answer?
geposted Wed 21 Nov 18 @ 10:22 am
I think that it may be because some (like me) don't understand the question...
Do you mean beatlock?
That's on the scratch pane
Anyway... Here are 5 ways you can use Sync in VDJ
geposted Wed 21 Nov 18 @ 11:11 am
thx but this is not what i was looking for. on top of the waveforms is the beatkeeper... it counts the beats of the phase 1,2,3,4,....16. I want to beat or phase sync tracks. When Deck A is on beat 3 of the beatkeeper (phase) i want Deck B to start witch beat 3 - independently if it would usually start a beat 1 etc.
Do you understand what i mean? ;)
geposted Wed 21 Nov 18 @ 11:53 am
You just need to set the globalQuantize option to 4 beats then
geposted Wed 21 Nov 18 @ 12:00 pm
thank you, just tested.... does not work:( tried "4" and "16"...no luck
geposted Wed 21 Nov 18 @ 12:14 pm
if the custom button is pressed and deck a is in bar 14 of 16 for example, i want deck b to be in bar 14 of 16, too
geposted Wed 21 Nov 18 @ 12:18 pm
If you're bringing a new track in when the playing track is somewhere other than "the one" then you need to cue your incoming track to the appropriate place first, then bring it in on whatever "off beat" you're using/wanting.
You can't expect the software to know that you're bring tracks in on the "wrong" beat.
geposted Wed 21 Nov 18 @ 5:41 pm
the beatkeeper is exactly a helper for finding the "right beat".
since it guesses what is beat 1 and beat 2 and...beat 16 it does not make sense if there's no automatic function for syncing the beat position of two tracks within a bar/phase
geposted Wed 21 Nov 18 @ 5:58 pm
