Topic: Script Experts wanted
ewewoHome userMember since 2018
Hi there, can anybody help me fix some vdjscripts which are buggy?
geposted Mon 19 Nov 18 @ 5:47 pm
Anybody?
geposted Mon 19 Nov 18 @ 7:40 pm
maybe if you post the problem scrips some people when they have time will have a look and post fixes
good luck :-)
geposted Mon 19 Nov 18 @ 11:08 pm
Go ahead, I'm getting back in to it after a disastrous few month.
geposted Tue 20 Nov 18 @ 2:40 am
Thank you!
geposted Tue 20 Nov 18 @ 7:46 am
@locodog: so you‘re available? ;-p
geposted Tue 20 Nov 18 @ 10:26 am
let me guess you script is top secret and you are not willing to post it?
aaaah well good luck.
geposted Tue 20 Nov 18 @ 11:27 am
Haha no;)
Ok 1st question: is it possible to crossfade bar/bpm relative? Instead of using values like crossfade 2000ms somethig like crossfade: 8bars
There this get_bpm command so it might be possible?
geposted Tue 20 Nov 18 @ 11:33 am
ok, here we go:
All scripts should generally be designed for keyboard keys or controller keys and bidirectional? work, so that the script works, whether Deck 1 or 2 is currently active.
For synchronous transitions, duration of fades etc should be bar-timed and not a static duration, for example: not 2000ms but something like 4bars. I do not know if that's possible, but maybe with "get_bpm" and a divide of the value or something similar?
For synchronous transitions, the sync should be "beat-synchronized" in the beatkeeper, ie not just synced, maybe this would be possible using "get_beat"?
Script 1 (asynchrone Transition, synced version possible):
Deck should play a backspin (4 bars long) while playing, and then immediately make a full crossfade to the other deck and start it.
set 'rsGainBS' '`gain' & gain -20% & slip on & effect_active 'backspin' & repeat_start_instant 'rsiBackSpin' 10ms & effect_active 'backspin' 1 ? nothing : repeat_stop 'rsiBackSpin' & play & slip off & get_var 'rsGainBS' & param_cast & gain & mix_now
known issues:
- Length of the backspin static and not tact-relative
- sometimes the backspin effect is not heard
- It generally works only with one deck, not on the other deck
Script 2 (synced Transition):
Activce Deck should simulate the typical engine-off effect of a record player and stop the active track, and the other deck should start slow (ie the opposite of Motor-On) begin. Between the two effects there should be a crossfade from one deck to another
slip on & effect_active 'brakeStart' & repeat_start_instant 'rsibrakeStart' 10ms & effect_active 'brakeStart' 1 ? nothing : repeat_stop 'rsibrakeStart' & play & slip off & mix_now
known issues:
- the crossfade takes too long
- the active deck is not stopped
- The inactive deck starts directly and does not provide the engine-off effect
Script 3 (asynchron Transition, synced version possible):
Deck active should loop a bar and then be pitched lower and slower (similar to the end of Timberlakes - cry me a river) and then fade to the other deck and then start this song.
slip on & loop 1 & repeat 235ms & down ? key 0 ? key -1 : key -1 ? key -2 : key -2 ? key -3 : key -4 : loop 0 & key 0 & slip off & mix_now
known issues:
- sometimes the script works, sometimes not
- Routine for crossfade not implemented
- Loop does not slow down (routine is not implemented)
Script 4 (synced Transition)
Deck active should loop a bar and then, after a loop pass, half the length of the loop and repeat the whole process until 1/4 loop is repeated and then crossfade directly on the other deck and start this track
loop 2 & down ? blink 300ms & repeat_start "rsAHL" 33ms & loop 2 ? loop_position & param_bigger 90% ? set "top" 1 : var "top" 1 ? loop 1 & set "top" 0 : nothing : loop 1 ? loop_position & param_bigger 90% ? set "top" 1 : var "top" 1 ? loop 0.5 & set "top" 0 : nothing : nothing : loop 0 & repeat_stop "rsAHL"
known issues:
- unfortunately does not work VDJ 8.3 (copied from the script examples)
- Routine for switch to the other track is not implemented
Script 5 (synced Transition)
Crossfade to the inactive deck which starts back forth - the crossfader now shifts to the other deck very fast (bpm relative, not static) to the other deck, the whole thing is getting faster, from 1/4-beat fader switches to 1/16 and in the end the crossfader will remain on the new track
Here I completely miss the approach, because I do not know how to create such "switches" isochronous and not temporally static
cycle "$AutoXF" 2 & var_equal "$AutoXF" 1 ? var_equal "$XFside" 1 ? deck master repeat_start_instant "rsiXF" 10ms 101 & crossfader +1% & crossfader 100% ? deck master repeat_stop "rsiXF" & set "$XFside" 2 & set "$AutoXF" 0 : nothing : var_equal "$XFside" 2 ? deck master repeat_start_instant "rsiXF" 10ms 101 & crossfader -1% & crossfader 0% ? deck master repeat_stop "rsiXF" & set "$XFside" 1 & set "$AutoXF" 0 : nothing : nothing : deck master repeat_stop "rsiXF"
known issues:
- Script not functional
Script 6 (synced Transition)
The active deck should execute an "infinite" but fadening echo / delay effect at the push of a button and then sync to the inactive deck and start it
effect_button "loop out" 1 1 & effect_button "loop out" 2 1 & effect_slider "loop out" 1 50% & effect_slider "loop out" 2 24% & effect_slider "echo" 1 50% & effect_slider "echo" 2 50% & effect_active "loop out" 1 & effect_active "echo" 1 & repeat_start_instant "rsiLoopOutOff" 33ms & effect_active "loop out" ? nothing : repeat_stop "rsiLoopOutOff" & repeat_start "rsEchoOff" 2000ms 1 effect_active "echo" 0 & mix_now & auto_crossfade 8000ms
known issues:
- Script does not fade Delay / Echo effect
- Script sometimes does not work
- Clock-accurate crossfade functions not implemented
Script 7 (synced Transition)
The active deck should switch to the other track at for example the last beat of the song, the new track should start immediately (hard cut).
cycle "$AutoXF" 2 & var_equal "$AutoXF" 1 ? var_equal "$XFside" 1 ? deck master repeat_start_instant "rsiXF" 10ms 101 & crossfader +100% & crossfader 100% ? deck master repeat_stop "rsiXF" & set "$XFside" 2 & set "$AutoXF" 0 : nothing : var_equal "$XFside" 2 ? deck master repeat_start_instant "rsiXF" 10ms 101 & crossfader -100% & crossfader 0% ? deck master repeat_stop "rsiXF" & set "$XFside" 1 & set "$AutoXF" 0 : nothing : nothing : deck master repeat_stop "rsiXF"
known issues:
- Script not accurate/beat-synchronized (in Beatkeeper)
Script 8 (synced Transition)
The active deck should crossfade to the other deck with a duration of 8 Bars (beat synced within beatkeeper)
crossfader 0% ? auto_crossfade 1000ms & deck 2 play : auto_crossfade 1000ms & deck 1 play
known issues:
- Script not accurate (in Beatkeeper)
- Duration of face not relative but static
Script 9 (synced Transition)
Das aktive Deck soll zum anderen Deck mit einer Dauer von 8 Bars crossfaden und dieses schlagggenau im Beatkeeper starten und dabei die EQ Crossfaden
repeat_start_instant 'eqchanger' 100ms 50 & deck 1 eq_low -1% & deck 1 eq_high -1% & deck 2 eq_low +1% & deck 2 eq_high +1%
known issues:
- EQ thread works only on a deck, so it is not bidirectional
geposted Tue 20 Nov 18 @ 1:26 pm
Sorry for my bad translation...
geposted Tue 20 Nov 18 @ 9:15 pm
is somebody out there who could save my scripts? ;)
geposted Wed 21 Nov 18 @ 8:07 pm
