Topic: Database Question
Ok I have a 4tb hard drive that is split into 4 different partitions. Which means theres 4 different database files.
So if another program (example Sound Switch) asks me to point it to my database how does it know theres more then 1??
If I point it (Sound Switch) to the database on my C:/ drive does that also include the others databases that are on my external hard drive??
geposted Mon 19 Nov 18 @ 11:11 pm
You'd have to ask Sound Switch, we don't know what Sound Switch does.
It should read the database on each drive that it needs data from. If it only reads the database on drive C, then it will only have information about the music on drive C.
geposted Tue 20 Nov 18 @ 8:01 am
Yes I figured you say ask them lol!!
I might have found a problem on their end so I just wanted to confirm the whole reading of all databases from you.
I’m gonna run a few more test and then hit up Matt.
Thanks for the time and info.
geposted Wed 21 Nov 18 @ 4:57 am
